(O1) Problem z odpalaniem na ciepłym silniku kody błędów VAG
Posty
  • kelox99
    • 6
    Ale to nie jest śmieszne - To szczera prawda k
    wtx, Octavią 4x4 hehehhehe
  • kamel_waw
    • 44
    proszę o pomoc w zdiagnozowaniu problemu odpalania na ciepłym silniku. O1, 1998, 1,8, 20V.
    Odczyt z VAG:
    VAG-COM Version: Release 311.2-N
    Chassis Type: 1U - Skoda Octavia
    Scan: 01,02,03,08,15,17,19,35,46,56
    Address 01 -------------------------------------------------------
    Controller: 06A 906 018 DJ
    Component: 1,8l R4/5V MOTR AT V01
    Coding: 04030
    Shop #: WSC 31480
    5 Faults Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    00561 - Mixture Adaptation
    15-00 - Adaptation Limit (Add) Not Reached
    16706 - Engine Speed Sensor (G28): No Signal
    P0322 - 35-10 - - - Intermittent
    16497 - Intake Air Temp. Sensor (G42): Signal too High
    P0113 - 35-10 - - - Intermittent
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    Readiness: N/A
    Address 02 -------------------------------------------------------
    Controller: 01M 927 733 FN
    Component: AG4 Getriebe 01M 3949
    Coding: 00000
    Shop #: WSC 00026
    No fault code found.
    Address 03 -------------------------------------------------------
    Controller: 1J0 907 379 H
    Component: ABS/EDS 20 IE CAN 0001
    Coding: 13504
    Shop #: WSC 31480
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 1U1 919 034 C
    Component: A4-KOMBIINSTR. VDO V22
    Coding: 02142
    Shop #: WSC 31480
    IMMO-IDENTNR: SKZ7Z0W0172368
    1 Fault Found:
    01176 - Key
    07-00 - Signal to Low
    Address 46 -------------------------------------------------------
    Controller: 1J0 959 799 Q
    Component: 5S Zentral-SG Komf. 0001
    Coding: 04097
    Shop #: WSC 31480
    5 Faults Found:
    00849 - S-contact at Ignition/Starter Switch (D)
    25-00 - Unknown Switch Condition
    00928 - Locking Module for Central Locking: Front Driver Side (F220)
    27-10 - Implausible Signal - Intermittent
    00943 - Heated Exterior Mirror: Driver Side (Z4)
    35-00 - -
    00930 - Locking Module for Central Locking: Rear Left (F222)
    27-00 - Implausible Signal
    00935 - Electric Window Motor: Rear Right (V27)
    62-00 - No or Incorrect Adjustment
    End -------------------------------------------------------
    pozdrawiam i dziękuję z góry za pomoc.
    • gamblerpl
      • 56
      podlaczam sie pod ten post
      • kamel_waw
        • 44
        Zamieszczone przez gamblerpl
        Masz ten sam odczyt z VAGa czy te same objawy?
        • Krzycho-63
          • 628
          Błędy dotyczące silnika-adres 01(czujnik temperatury zasysanego powietrza,przepływomierz,zły skład mieszanki) proponuję wykasować i następnie zobaczyć ,które się powtórzą.Adres 46 dotyczy modułu komfortu i błędów z centralnego zamka i szyby-nie ma to wpływu na uruchamianie silnika.
          Skoda Superb II Ambition
          2.0 TDI CR 170 KM
          https://www.facebook.com/kjautoelektronika/
          • kamel_waw
            • 44
            Zamieszczone przez Krzycho-63
            Ok, dzięki, biorę się za kasowanie i zobaczymy co dalej. Najbardziej mnie martwi to uruchamianie bo nie wiem kiedy sprawi niespodziankę :?
            Dobra, błędy skasowane, uruchomiłem silnik, pochodził trochę, znowu test i błędów nie było.
            Pozostaje kwestia tego immo, czy może mieć to wpływ na niemożność odpalenia?
            Od razu zaznaczam że kontrolka immo gaśnie.
            [ Dodano: Czw 10 Cze, 10 15:42 ]
            News z ostatniej chwili. Pojawia się jeden błąd i chyba tu pies pogrzebany:
            Coding: 04097
            Shop #: WSC 31480
            1 Fault Found:
            Czyżby coś w stacyjce? Co to jest ten S-contact?
            [ Dodano: Pią 25 Cze, 10 12:35 ]
            Zrobione.
            Ten pan powodował problem:
            czujnik położenia wału. Po wymianie śmiga.
